Information for making the most of using a toilet
Discussion in 'Off-Topic' started by takao21203, Mar 12, 2015.
  1. takao21203
    Thread Starter Distinguished Member
    Apr 28, 2012
    3,578
    463
    Here are some tips and you can write your too.
    1. Always wipe the seat with wet toilet paper- first it should be clean, and also to avoid bacteria.
    2. If there is a large object in the bowl which doesnt flush properly here's a stunning trick: cover it generously with toilet paper. It will flush down, because the area exposed to the water stream is much bigger.
    3. Dont make mobile phone calls from the toilet. Really, are you serious? Its happening in shopping malls and companies all the time. I wouldnt want to be called from a toilet.
    4. If you use public toilet do flush it, dont try to save water. Its quite annoying for the next person.
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    I must have missed that meeting.:(
    Max.
  3. cmartinez
    Jan 17, 2007
    3,698
    2,788
    For that second point... I'd also suggest walking into the stall armed with a baseball bat or a low caliber gun to kill the large object that refuses to be flushed...
    ErnieM likes this.
  4. djsfantasi
    Apr 11, 2010
    2,905
    878
    Some definitely weird posts lately...
    Sinus23, #12 and wayneh like this.
  5. GopherT
    Nov 23, 2012
    6,310
    4,031
    I had to look twice, I thought "Mathematics!" was back.
    shortbus likes this.
  6. takao21203
    Apr 28, 2012
    3,578
    463
    If you practice it like explained you'll have a higher level of hygiene.
    Oh, here's one more, slightly anatomic:
    5. you can actually learn how to do the procedure without toilet paper, when you try to control the relevant muscles appropiately.
    Maybe you laugh but its a big topic. In many countries not all people can use even a simple toilet.
    There is no awareness of neccessary hygiene either.
    6. Its possible to modify the flush mechanism so you can turn it off before all the water has been used.
    I think, and I'm certain to say, writing these few and easy steps 100 times on a blackboard would give more benefit to mankind than the "music" lessons we received in school, learning the notes system without even hearing or seeing printed one single partiture of a music piece.
  7. Glenn Holland
    Member
    Dec 26, 2014
    359
    114
    I thought I logged onto All About Circuits, but somehow I got redirected to the "Twilight Zone".Com. o_O
    PackratKing likes this.
  8. takao21203
    Apr 28, 2012
    3,578
    463
  9. MrChips
    Oct 2, 2009
    12,635
    3,454
    If there is a spider in the toilet make sure that takao can ID it first before you flush.
    Sinus23 and cmartinez like this.
  10. Glenn Holland
    Member
    Dec 26, 2014
    359
    114
    Here's something remotely relevant to the subject of toilets and sanitation.
    Most of Metro Manila is not connected to an urban sewer system and they use septic tanks (there are over a million of them in the city) for disposal of sewage. Filipino plumbing contractors frequently hire "Pozo Negro Divers" to clean them out:
    https://www.youtube.com/watch?v=uvzKXZiN-Dw&t=4m30s
  11. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    In Singapore you receive a public canning and a heavy fine if caught urinating in public especially in an elevator, it is also against the law and comes with a heavy fine if you omit to flush the toilet.
    Chewing gum is also heavily frowned on!
    Max.
  12. Lestraveled
    May 19, 2014
    1,957
    1,218
    What was your lasting memory from the last time you used the toilet in a commercial aircraft. I am not talking about number 1, it's the number 2 that brings it home. Stuck into a oddly shaped cramped space, buffeted by 600 MPH winds at 32 thousand feet altitude. They call that toilet paper??? That's not toilet paper! I have envelope address labels that are bigger than that. CRAP! And that blue water....Ohhh, just forget it.
  13. Glenn Holland
    Member
    Dec 26, 2014
    359
    114
    The small sized toilet paper was to save weight and hence use less jet fuel. :p
  14. cmartinez
    Jan 17, 2007
    3,698
    2,788
  15. DickCappels
    Aug 21, 2008
    2,772
    669
    Toilet seat?
  16. #12
    Nov 30, 2010
    16,693
    7,334
    You're telling a bunch of high tech nerds how to wipe their butts? :eek:
    I think you have addressed the wrong audience.
    ps, I had no idea things were so bad in Ireland. :(
  17. jpanhalt
    Jan 18, 2008
    5,699
    909
    That is a nice homage to a vital part of our anatomy. A general surgeon I knew used to sum up the complex role of the anus by a simple thought experiment. In his experiment, he would take a mason jar, add some stones, sand, mud and a little water, and shake it up. He would then ask, how do you let only the gas out the bottom?
    John
  18. Kermit2
    Feb 5, 2010
    3,851
    966
    professor Emmot Brown came up with the idea of the flux capacitor in the toilet.
  19. wayneh
    Sep 9, 2010
    12,388
    3,244
    One of the most challenging problems in Chemical Engineering is 3-phase flow, solid, liquid and gas. Handled for us readily by the humble anus. Knock on wood.
  20. mattbullet
    Member
    Nov 29, 2008
    20
    12
    My recipe for toilet paper: Brown it on one side and just throw it in the pot.
    (Sorry. )
