Info source re: add a USB interface 80C52 project, please?
Discussion in 'Embedded Systems and Microcontrollers' started by Louise, Oct 5, 2010.
  1. Louise
    Jan 17, 2010
    13
    Hello Everybody!
    I intend to increase the functionality of an 80C52 project by adding a USB controller and writing the necessary code so that I can attach USB peripherals to the board. (By peripherals, I mean both 'devices' and 'functions'). Does anyone know of a good source of information to assist me in this task, please? At the moment I am using "USB in a Nutshell" by Craig Peacock, but I could do with something a bit more in-depth really. Many thanks,in anticipation,
    Louise
    P.s. I would prefer to use Assembler, but am prepared to use (Borland) Turbo C if necessary.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    I've found the MAX3421 a very easy to use device. There are a number of classes, and you may want to zero in on a specific one, then study it's requirements.
    And quite frankly, I would never attempt such an adventure in assembly, Although you can find many code examples in assembly. I use the Atmel 8051 core devices and find they have a good selection of coding examples.
  4. Louise
    Jan 17, 2010
    13
    Many thanks to GetDeviceInfo and beenthere for their suggestions. I will doubtless be back for more help with this!!
