Info on variable gap condenser/capacitor
Discussion in 'The Projects Forum' started by Gunsmithing, Mar 7, 2012.
  1. Gunsmithing
    Feb 19, 2012
    5
    Has any one use and or built a variable gap condenser / capacitor using 2 plates and a screw
    How well does this work
    See drawing Capacitor Variable.PDF
    Dave
  2. crutschow
    Mar 14, 2008
    13,479
    3,366
    It should work fine if you need a small, variable capacitor.
    Gunsmithing likes this.
  3. Gunsmithing
    Feb 19, 2012
    5
    Thank you
    What doing is working a radio mostly shop made
    Dave
  4. ErnieM
    Apr 24, 2011
    7,436
    1,625
    It's the simple basic physics that makes these things work.
    For you youngsters who never saw an analog tuned radio front end the tuning cap was a odd number series of half circles. As you turned the knob the middle pieces would rotate in and out of the stack. Many pairs were used to work in parallel and get more capacitance (or were they in series to get less? I never checked lol.)
  5. crutschow
    Mar 14, 2008
    13,479
    3,366
    Yes, I remember looking inside our old AM radio when I was a kid and observing those variable caps move as I tuned the radio. (Those old radios had the back open so you could easily observe the innards.) It was turned by a heavy string wrapped around a pulley which was wound around the tuning know shaft and also moved the dial indicator. I remember the string broke once and we had to take it to the repair shop to have a new string installed.
    Here's an example of one of the caps. This one has two separate caps. One tunes the RF input and the other tunes the IF mixer oscillator frequency. All the fins are in parallel.
  6. BillB3857
    Feb 28, 2009
    2,402
    348
    Many of these caps in old radios also had "trimmer caps" attached. These were rectangular in shape with plates separated with mica and adjusted by a screw. This was used to help adjust the local oscillator and receiving RF section to produce a more accurate IF.
  7. Gunsmithing
    Feb 19, 2012
    5
    I update the Variable_Capacitor Drawing
    It show shows a 4 gang and other details
    Dave
