Info on the MT8870 receiver
Discussion in 'The Projects Forum' started by corner_boy, Nov 18, 2008.
  1. corner_boy
    Thread Starter Active Member
    Jun 24, 2008
    36
    I'm trying to connect the sample circuit like done in the data sheet
    http://www.electronicsforu.com/EFYLinux/circuit/jun2003/CI-2-DTMF.pdf
    I simply just don't know how to connect to the telephone line. Simply put i don't see how to connect it, any assistance from anyone is greatly appreciated. Thank you
    PS if i used a 5.1 volts zener diode instead of a 5.6V would that be a problem. I also have 6.1V available.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The connection is pretty clearly shown (notice the two lines identified as "phone line"). Or are you asking about how to physically connect to the phone line? I would build it with an RJ-11 connector and just use a molded telco cable. The red and green wires are usually the ones in use.
    This is probably going to be difficult except on a printed circuit board. That also applies to your digital record/playback IC. If you search the forums, you will find several threads that discuss how to go about making PCB's, including links to freeware CAD programs to do the layout.
  3. corner_boy
    Jun 24, 2008
    36
    ya im asking how to physically do it.
    do you know about the 5.6V zener diode question i asked though?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    5.1 volts would be better than the 6.1. As lons as you're taking the trouble, why not get the 5.6?
    See my previous post about the connection. To expand a bit, make it so a telephone extension cord plugs into an RJ-11 modular connector. You can obtain them that will mount to a chassis and wire into a PCB, or ones that mount on a PCB.
    This is a big project, but you can learn quite a lot from doing it.
  5. corner_boy
    Jun 24, 2008
    36
    im waiting on the 5.6volts in the mail, i only ask because those are the closest availible now
  6. corner_boy
    Jun 24, 2008
    36
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Xtal is shorthand for crystal. Those 3.57 MHz crystals used to be common as dirt because they were used for the color burst oscillator in TV's. They are probably still available.
    Here's a link for some info - http://en.wikipedia.org/wiki/Crystal_oscillator.
  8. corner_boy
    Jun 24, 2008
    36
    oh wow, thanx. any idea on where to purchase that online?
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Mouser has them. Try part #695-HC49US-357-U @$0.58.
  10. corner_boy
    Jun 24, 2008
    36
    thank u "beenthere"
    ---> I had a question in the wire connection. The phone line to wall has 4 wires and I'm sure which one will go to what side of the diagram in the link i provided earlier.
    anyone have an idea or should i just plug and pray for the best, =)
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    In North America, the green and red wires are used in a 4-wires telephone line. The yellow and black might be used for a second telephone line.
  12. corner_boy
    Jun 24, 2008
    36
    thanx for that.
    I did it at my house and the thing worked perfectly thanx. But i attempted at my skool, and im guessing because its in a network it didnt work with the red and green. But i also connected the black and yellow with it and it only caused silence in the phone.
