Info from .bak in SQL Server 2005
Discussion in 'Programmer's Corner' started by DanielNetrval, Aug 23, 2016.
Thread Status:
Not open for further replies.
  1. DanielNetrval
    Aug 15, 2016
    I have a 6GB .bak file that, when check it in the file to use for restore, the file shows 'Incomplete'.
    I need to extract the .mdf part of the .bak file since I don't need the .log file.
    There should be some way to do this or some tool out there that will either repair the .bak file so it doesn't show 'Incomplete', or that will extract the .mdf file so I can use it or repair just the .mdf file. There may even be a SQL script that will do this. I've done extensive searches and can't find an answer. I'm quite sure I'm not the only one who has encountered this issue.
    Suggestions/solutions?
    AdamHenriksen likes this.
  2. WBahn
    Mar 31, 2012
    18,079
    4,917
Thread Status:
