INFO: A low-voltage, bulk-driven MOSFET current mirror for CMOStechnology
Discussion in 'General Electronics Chat' started by xn47, Jun 14, 2007.
Thread Status:
Not open for further replies.
  1. xn47
    May 22, 2007
    22
    A bulk-driven, MOSFET current mirror is described which is capable of operating at power supplies down to 1 V using standard CMOS technologies with threshold voltages in the range of }0.8 V. The bulk-driven MOSFET configuration removes the requirement that the input voltage of the current mirror equal VGS>VT. At VDD/VSS of+0.75 V/-0.75 V, measurements on simple current mirrors using this new technique require only about 0.1 V across the input device of the current mirror circuit and exhibit saturation voltages on the output device of the current mirror comparable to that of standard simple current mirrors. The operation and first-order models for the bulk-driven MOSFET are presented in this paper along with the operation and experimental results of a simple, bulk-driven mirror
    Moderator's note: The above material comes from a IEEE abstract here - http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=523807. The forum does not support material from other sources that is not properly attributed. The poster is warned not to do this again.
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    And we care about this why? Where is the link to the source? Are you posting just to raise your post count? What?
  3. cumesoftware
    Apr 27, 2007
    1,330
    11
    Cannot compute.
Thread Status:
