Infinite Impedance Observation
Discussion in 'Homework Help' started by Cerkit, Jan 9, 2009.
  1. Cerkit
    Thread Starter Active Member
    Jan 4, 2009
    275
    Hi. I am a bit unsure about what to do with the following circuit. The specifications say that I should measure the voltage that would be observed at node 2 via an infinite impedance observation when a voltage between 9.8 and 10.2 is applied at node 1.
    Code ( (Unknown Language)):
    1.        ------------------ONode1
    2.                     |
    3.                    --
    4.                    Ra 560R
    5.                    --
    6.                     |
    7.                     ---------------------ONode 2
    8.                     |               |
    9.                    --¬ Zener       --
    10.                     Δ               Rb 4K7
    11.                     |               --
    12.                     |               |
    13.                     ----------------O Ground
    The zener breakdown voltage is between 2.5 and 7.5V. The resistors values are such that if P2 is unloaded the diode will be in breakdown with 10V at node1.
    Is this as simple as checking the voltage at node2 with an applied voltage of approx 10V at node1 ???
  2. mik3
    Feb 4, 2008
    4,846
    63
    If this an experiment just do what they say. And yes you can check it like that.
  3. Cerkit
    Jan 4, 2009
    275
    Ok was just a bit confused about the infinite impedance observation. How am I supposed to implement that in measurement?
  4. mik3
    Feb 4, 2008
    4,846
    63
    What is an infinite impedance observation?
  5. Cerkit
    Jan 4, 2009
    275
    I believe it means where absolutely not current is leaking through voltmeter. I suppose I could put a very large resistor after node 2 and then take the voltage measurement. Would that work??
  6. mik3
    Feb 4, 2008
    4,846
    63
    No, you can't do this because a voltage drop will occur across the large resistor and you will measure less voltage. Use a JFET input op amp as a voltage follower to buffer the node. However, I don't think you need to get into all this trouble. Good multimeters draw little current.
