Infinite 12 volts caught out! :p :p
Discussion in 'The Projects Forum' started by Lightfire, Feb 6, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    I found this battery provider. It is VERY well-known battery provider in the Philippines. As almost of cars here in the Philippines are using that battery. :)
    So, I found this one. It's industrial batteries. What is that???
    Is that gives infinite 12 volts supply??? :D :D
    http://motolite.com/industrial.php
    If someone can explain me that kind of battery. Please please please, tell it to me... ;D ;D
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    The sales sheet describes most of the industrial batteries as being "deep-cycle". So they are allowed to be discharged to a fairly low voltage (a deep voltage). Their current output is not as high as a car battery so they are not suitable for starting a car engine.
    A car battery is designed to supply hundreds of Amps for a few seconds then it is immediately recharged. It is built differently than an industrial battery.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Pretty much what was discussed in the other thread. You can use the battery, but be sure to keep it charged too. You ever run it dead it may be ruined.
