Inductors
Discussion in 'Homework Help' started by KCHARROIS, Jul 10, 2012.
  1. KCHARROIS
    Jun 29, 2012
    292
    Hello, I'm looking at inductors and I've notice some look like resistors, some with ferrite cores or some with just coils of copper with air core. Does it matter which one you use like say for an oscillator? Or do they all do the same thing?
  2. MrChips
    Oct 2, 2009
    12,635
    3,453
    They all have different values of inductances.
    Air core coils have very low inductances and are used in RF circuits.
    Inductors looking like resistors are your typical inductors for general purpose use.
    Ferrite beads are used for power supply filters to reject high frequencies.
  3. KCHARROIS
    Jun 29, 2012
    292
    So what would you recommend for an oscillator circuit?
  4. MrChips
    Oct 2, 2009
    12,635
    3,453
    Depends on your frequency.
  5. KCHARROIS
    Jun 29, 2012
    292
    Frequency I wish to achieve is 2 Mhz.
  6. MrChips
    Oct 2, 2009
    12,635
    3,453
    Next you have to show your circuit.
  7. KCHARROIS
    Jun 29, 2012
    292
    Here's the circuit
  8. KCHARROIS
    Jun 29, 2012
    292
    Sorry this pic is bigger
  9. t_n_k
    Mar 6, 2009
    5,448
    783
    It's a Colpitts oscillator. RF chokes would be fine - you may need to adjust something (capacitors say) to obtain the 2Mhz.
    C1=C2=6.2nF say
  10. OscGuru
    Apr 3, 2012
    An important thing to remember is that inductors have parallel capacitance which is distributed between coils and or the package capacitance. This parallel capacitance will resonate with the inductor inductance to give you a, parallel, high impedance resonance. This frequency is called the SRF, self resonance frequency. If you want to have a desired inductance at a given frequency make sure you use a an inductor that has a much higher SRF than your use frequency. The parallel capacitance will force the effective inductance to increase in frequency to SRF then above that point it looks like capacitor. RF chokes are inductors used above their SRF and behave as low value capacitors.
