inductors
lemon
Joined Jan 28, 2010
125
A circuit comprises an inductor of 700mH of negligible resistance connected in series with a 15Ω resistor and a 24V d.c. source. Calculate:
a) i) the initial rate of change of current ii)the time constant (T) for the circuit
b) the value of the current after 1T seconds, and ii) the time to develop maximum current.
The attempt at a solution
The inductor has negligible resistance so we can use V=IR to calculate the current through the circuit = 24/15 = 1.6A
V-iR/L = 24-(1.6x15)/(700x10-3)=0
So, I got zero. So, I got nothing, right?
What am I doing wrong?
I suck at this! :confused:
lemon
Joined Jan 28, 2010
125
I could't work out in the editor how to show something raised to a power. Hope you can understand this easily.
a)i) So, the initial rate of change of current is when di/dt=V/L
Which is 24V/(700x10^-3)=34.3A/s (3s.f.)
ii) the time constant (T) for the circuit
This is not given in the same way as the time constant for a series connected CR.
It is, instead, circuit T=L/R
Therefore T=(700x10^-3)/15Ω=0.0467s or 0.05s (2s.f.)
Well there are two equations here - one for growth of current and one for decay.
I think it is growth because the question says 'initial rate'
Growth=I(1-e(-t/T))=34.3(1-e^(-0.05/0.05))=21.68A (2s.f.)
But - Currents will be approximately 63% or their final values after 1T when growing.
Imax=V/R=24/15=1.6A
So, at 1T, I=0.63x1.6=1.008A
These figures don't agree
ii) the time to develop maximum current. When t≥5T.
Imax=V/R=24/15=1.6A
mik3
Joined Feb 4, 2008
4,843
Imax=V/R=24/15=1.6A
You have to put I=Imax in the equation and not the rate of change.
mik3
Joined Feb 4, 2008
4,843
Imax=V/R=24/15=1.6A
To find the time rearrange i=Imax(1-e(-t/T))
as to get t=-T*ln(-i/Imax+1)
when i=Imax, ln(-1+1)=ln(0)=infinity
Thus, the time to reach Imax is infinite. This the reason it is said that Imax is reached after 5T.
lemon
Joined Jan 28, 2010
125
t=-T*ln(-i/Imax+1)
Well. I had two values of i (not sure which one was correct)
t=-0.05*ln(-1.008/1.6+1)=i get mathematical error
or
t=-0.05*ln(-21.68/1.6+1)=i get mathematical error
mik3
Joined Feb 4, 2008
4,843
t=-T*ln(-i/Imax+1)
or
In the first case you shouldn't get a mathematical error however the value for i is wrong. It should be i=Imax.
In the second case you will get a mathematical error because you have a negative number in the ln() which is not allowed.
lemon
Joined Jan 28, 2010
125
if i=Imax then i=1.6A
t=-0.05*ln(-1.6/1.6+1)
but i'm confused cause they both have a minus sign in the ln(-1.008) and ln(-21.68)
but which one of these values is also correct from the earlier workings?
Imax=V/R=24/15=1.6A
mik3
Joined Feb 4, 2008
4,843
ln(-1.008/1.6+1)=ln(0.37)
ln(-21.68/1.6+1)=ln(-12.55) this is wrong because 21.68 is wrong
The correct value of current after T is 1.008.
lemon
Joined Jan 28, 2010
125
hold on!
Your earlier post:
So, the answer to this part of the question is infinity?
It can't be -1s. It doesn't make any sense for the current to be maximum at -1s, the circuit isn't connected before time t=0.
mik3
Joined Feb 4, 2008
4,843
hold on!
Your earlier post:
If you calculate the time mathematically, then (t) is infinity. However, if you assume that (i) reaches Imax after 5T, then t=5*0.05=0.25.
lemon
Joined Jan 28, 2010
125
ahh! I see. So the answer to my question is:
But, you have been showing me how to calculate the time mathematically, then (t) is infinity?
But why is my answer -1s?
mik3
Joined Feb 4, 2008
4,843
Yes, the exact time is infinity however we assume that after 5T it reaches Imax because (i) is very close to Imax.
How you get -1?
lemon
Joined Jan 28, 2010
125
How you get -1?
It's a good question. I must have eaten a strange fruit this morning. I will use 0.25s then. Once again mik3, thanks for all your great support today. It is very appreciated.
