Inductors vs. Capacitors
Discussion in 'General Electronics Chat' started by hondabones, Feb 5, 2010.
  1. hondabones
    Thread Starter Active Member
    Sep 29, 2009
    123
    Hello All!
    I noticed a few similarities in the calculations. Like, inductors in series are calculated similar to resistors in series. However, caps in series are similar to resistors in parallel.
    If you compare the two components (caps and inductors) they are basically inverses of each other. I am having trouble understanding the practical application and the purpose of these two components.
    They have such a unique relationship there must be some reasoning behind this. We are already beginning to learn series RLC circuits. I would like to understand the inductor vs. the capacitor before we combine the two components.
    Jim
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    The light bulb will go off when you study "resonant circuits".
  3. hondabones
    Sep 29, 2009
    123
    We did study resonate frequency just yesterday. There is no light bulb involve at this time so I don't understand your post at this time.
    Thank you for your reply. I welcome any input. I absolutely love my decision to get into electronics.
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    The nugget that you obviously missed while studying resonant circuits is that capacitive reactance cancels inductive reactance.
  5. hondabones
    Sep 29, 2009
    123
    Your probably right. I know that when XL goes up XC goes down. Let me rephrase that. As frequency goes down XL goes up and XC goes down. At the point where XL and XC are the same is resonate frequency. Did I accurately state this?
  6. alphacat
    Jun 6, 2009
    186
    As frequency decreases, XL (ωL) decreases and XC (1/[ωC]) increases.
  7. KL7AJ
    Nov 4, 2008
    2,047
    294
    Here's a little algebraic gymnastics you can do, if you're up to it. In fact, I just demonstrated it to my class last night!
    XL = 2*pi*fL
    XC = 1/2*fC
    Set 2*pi*fL= 1/2*pi*fC
    Now solve for f.
    This will give you the resonant frequency formula in terms of L and C.
    Great exercise. :)
    eric
  8. hondabones
    Sep 29, 2009
    123
    No kidding! We just learned that last night in class too.
    f = 1/2pi√(LC)
  9. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Both inductors and caps. shift the phase relationship between voltage and current. In exactly opposite directions. Becomes much clearer in the complex plane. Wait for it, it is so cool.
  10. Von
    Oct 29, 2008
    65
    ELI the ICE-man!
  11. AllVol
    Nov 22, 2005
    55
    Real numbers and imaginary ones!
  12. hondabones
    Sep 29, 2009
    123
    ELI the ICE person
    As my instructor puts it:rolleyes:
  13. Ron H
    Apr 14, 2005
    7,050
    657
    That's still sexist. "Son" is gender-specific. it should be ELI the ICE perchild.
  14. hondabones
    Sep 29, 2009
    123
    Good point.
  15. jans123
    Jan 30, 2010
    20
    Another aspect is that inductors and capicators store energy, resistors don't. Inductors can give the energy away as very nasty high voltage when circuits opens and capacitors can deliver banging currents when circuits closes.
    Resistors just tries to convert the energy it gets into heat.
    OUCH!
  16. hondabones
    Sep 29, 2009
    123
    This basically answers my question.
    You're saying that inductors effect voltage and caps effect current. Right?
  17. jans123
    Jan 30, 2010
    20
    In a way... yes, but it is more complex than that. Inductors don't like changes in current and tries to keep it constant. It has to do with the magnetic fields building up and braking down. It stores energy as a magnetic fild, whilst capicators shuffles charges (electrons) and don't like changes in the voltage.
    It is really the moving electrons in the inductor that creates the magnetic field and if you tries to break the current trough a inductor the collapsing magnetic field will induce voltage in the windings that tries to keep the electrons going at the same rate, whatever the sice of the beak in the circuit are, that's why a arch of current (sorry my English vocabulary is limited) flow between the contacts and damage the switches. On the other hand, the capicator stores energy as electrons and the bigger the difference is between the voltage on the capicator and the voltage source is when you connect it, the bigger the current are when the switch is turned on.
    Sorry, can't give a simple answer. If I try i would probably end up in an even bigger confusion.
  18. KL7AJ
    Nov 4, 2008
    2,047
    294
    He he! Well, obviously great minds travel the same rails. :)
    eric
