inductors in ac circuits
Discussion in 'General Electronics Chat' started by thesiliconekid, May 23, 2014.
  1. thesiliconekid
    May 23, 2014
    What happens when you put a second inductor in an AC circuit?
  2. #12
    Nov 30, 2010
    16,704
    7,351
    If it's in series, its impedance adds like 2 resistors. If it's in parallel, its impedance does an inverse add like 2 resistors.
  3. Alec_t
    Sep 17, 2013
    5,976
    1,136
    If there is magnetic coupling between the inductors then a current through one can induce a voltage across the other.
  4. wmodavis
    Oct 23, 2010
    737
    150
    If both leads are connected to ground it will have no effect.
