inductor vs resistor ID
Discussion in 'General Electronics Chat' started by electronis whiz, Aug 5, 2011.
  1. electronis whiz
    Jul 29, 2010
    519
    27
    i have taken alot of what apeared to be resistors out of things. then somwhere i figured out some inductors look like resistors too. is there any way to tell other than by using an ohm meter wether it's an inductor or resistor. if under a few ohm then it's probly an inductor? most things i beleve to be inductors are gree with coding stripes like resistors however have seen green used on resistors also. if i run across somthing an a PCB that has something other than R by it should i asume it's an inductor?
  2. praondevou
    Jul 9, 2011
    2,936
    489
    You could look at the designator on the PCB where you are taking the component from. R resistor, L inductor, C capacitor and so on.
    But in general it's quite clear if it's an inductor or a resistor. size, color bands etc.
  3. electronis whiz
    Jul 29, 2010
    519
    27
    all of them i have seen look just like 1/4 watt resistors but the bulges on the ends are smaller or gone. the problem is i have a small orginizer draw full of resistors and these things i have pulled from PCBs. acidently thinking L was some proprietary leter for resistor.
  4. ErnieM
    Apr 24, 2011
    7,436
    1,625
    Read the code off the item, compute resistance, and then measure it's resistance.
    If it is a resistor the two reading will agree. An inductor will have a much lower resistance. You could even just put the "low reading resistance" resistors in a drawer labeled "inductors" and get it pretty close.
  5. electronis whiz
    Jul 29, 2010
    519
    27
    thats kind of what i was thinking. i just used a DMM and if 1-2 ohm i [put it in inductors. i have been just putting all the inductors in a bin to recycle as i have no use for them.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
