This is a branch off a previous thread.
I have a need to rectify 120VAC to DC for a project I'm working on. In order to smooth out the ripple/pulsing, I naively thought I'd just add a large can-size capacitor after the rectifier. But I know these are dangerous, and fortunately came here and got some good advice on how to keep my limbs attached and eyes in their sockets.
One of the obvious flaws that was pointed out was that this large capacitor was going to have a huge inrush current- probably tripping the circuit breaker and/or frying the switch among other havoc. I also had under-sized the capacitor voltage but I've changed that already.
(Note: the capacitor I'm looking at is this one:
CDE 250v 26000uf Computer Grade Bus Capacitor
It was suggested that I put an inductor between the rectifier and the capacitor to limit the inrush current. My circuit will normally draw about 6 or 7 amps with a primarily resistive load- though could occasionally require as much as 20 or 30 amps.
I've been searching around and haven't been able to find the right formulas, or figure out how to apply them at least to determine what inductor I need.
Any suggestions on what size of inductor I'll need for this, or how to figure it out? Any special considerations for the on/off switch? I assume I'll want a flyback diode across the inductor correct?
Thanks in advance,
Eric
Thanks in advance,
Eric
