Inductor selection in MPPT Controller
Discussion in 'Embedded Systems and Microcontrollers' started by umar380, Dec 14, 2012.
Thread Status:
Not open for further replies.
  1. umar380
    Oct 4, 2012
    I am working on SMPS (Buck Converter) and having problem with inductor. I am using a locally available inductor wounded on ferrite core. The problem is that whenever I turn on the load, my driver IC is burnt. I am using IR2104 driver IC to drive mosfets.
    Remember problem is probably with inductor, not with the circuit. as when I use an inductor with lower amp rating(3-4 A), circuit works perfectly. but i need high amp rating (8-10 A).
    Can anyone suggest me a solution? Which inductor should I use? I'd appreciate if anyone share his experience of working with SMPSs and MPPT Controllers.
    Thanks.
  2. ErnieM
    Apr 24, 2011
    7,443
    1,628
    Unless you are willing to share your schematic no suggestions are possible.
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
Thread Status:
