I have a basic book (a little too basic actually) on tube amplifiers and I wanted to try building the guitar amp project from it. Most of the example circuits are hi-fi but I want to try a 5W guitar amp.
This circuit is the power supply for this amp directly from the book. When I simulate it the choke current goes up to a peak of 1A and RMS of 314mA in the first second before the caps charge up. I'm curious because the author suggested specific models of transformers and filter choke, and this choke is only rated to 200mA.
I don't have any experience with power supply chokes like this. Is it normal for them to exceed the rated current at startup, or is this a poor suggestion on the part of the author?
And while I'm at it, the power transformer suggested is rated to 60mA, 500V CT. My simulation shows a steady state current of 73mA RMS. Is RMS the correct figure to use in this case? The model doesn't specify inductance or DC resistance so I didn't include any in the simulation.
I estimated the current draw of the tubes in the simulation with resistors, based on the info from the book. About 33mA for the power tube and 9mA for the gain tubes. The circuit has (1) 12AX7, (1) 6SN7, and (1) 6V6GT.
