Inductor mount and testing
Discussion in 'General Electronics Chat' started by gusmas, Jun 11, 2013.
  1. gusmas
    Thread Starter Active Member
    Sep 27, 2008
    239
    Morning
    I am in need of some assistance. I have the following inductor and need to test it. Its arriving this week.
    Datasheet:
    http://docs-europe.electrocomponents.com/webdocs/1154/0900766b8115465d.pdf
    Its the RB6122.
    One thing I do not get is, is a single phase (DC) Inductor but it has 4 wires, does this mean that each side of the Inductor is split into 2 wires to handle the power OR does it mean this inductor is in actual fact 2 inductors built into one?
  2. Dodgydave
    Jun 22, 2012
    5,142
    768
    These are used in Switched mode psu's for filtering out the High frequency harmonics, they have two windings , one is for the "Positive" and the other is for the " Negative " supply and the harmonics cancel each other out in the coil.
    As for testing all you can do is measure the inductance or resistance of the windings.
  3. gusmas
    Sep 27, 2008
    239
    Ok, but I can use these inductors as i would normally? I want to use it inside a high power DC-DC converter. Calculations is already completed and this inductor is the one required for the design.
