Hi, I was just thinking about inductors and it occurred to me that when measuring the inductance of a coil and hypothetically if the inductance
was 1 mH and the coil was 100 turns then if you measured the inductance of a single turn in that coil, it should be around 10 uH? Is this correct
If you took 100 10 uH turns of wire and made a coil out of them then it should be 1 mH right?
