Inductor in Series with RF Signal
Discussion in 'General Electronics Chat' started by Sparky49, Apr 28, 2016.
  1. Sparky49
    Jul 16, 2011
    835
    417
    Hi all,
    My understanding is that an inductor will tend towards blocking an AC signal from passing through it.
    I have recently constructed a circuit for a small radio IC (http://www.farnell.com/datasheets/96892.pdf page 17, figure 8) for FSK operation. However, there is a an inductor in series with the output. How does this not block the RF energy? Is it because of the use of a loop antenna, rather than a monopole?
    If I were wanting to use a monopole antenna, what would be the best configuration? Simply remove the inductor?
    Many thanks for your time,
    Sparky
  2. nsaspook
    Aug 27, 2009
    3,006
    2,348
    The inductor and series capacitor form a band-pass filter (and what looks to part of a matching network) to let the fundamental carrier frequency pass while blocking others. No, you can't remove it.
    Sparky49 likes this.
  3. Sparky49
    Jul 16, 2011
    835
    417
    In that case, can I simply use a monopole antenna instead of the loop?
    Many thanks for your reply.
  4. wayneh
    Sep 9, 2010
    12,361
    3,220
    It resists changes in current, yes. But I'm not sure that's a useful way to think about an inductor in all applications. Plenty of AC - all the power entering my house and powering this computer - passes through a transformer, for instance.
  5. nsaspook
    Aug 27, 2009
    3,006
    2,348
    Maybe but it's not a simple matter of just replacing it with a random wire if you need to maintain range. The loop antenna forms a component matched tuned circuit optimized to transmit the signal. A proper 1/2 wave dipole or 1/4 wave with ground plane should work but would be the size of a baseball. The loop antenna is physically small but electrically large at the the transmit frequency.
    http://ww1.microchip.com/downloads/en/AppNotes/00831b.pdf
  6. Sparky49
    Jul 16, 2011
    835
    417
    Thanks, that example with the copper loop looks interesting, I will try to emulate that.
