Inductor Core Type?
Discussion in 'General Electronics Chat' started by R!f@@, Jun 16, 2016.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,791
    771
    Are these Air core or ferrite core types ?
  2. wayneh
    Sep 9, 2010
    12,388
    3,245
    I'm not sure we can tell from just looking, but I took a look at another supplier and see similar devices there that are ferrite core.
    More
    R!f@@ likes this.
  3. bertus
    Administrator
    Apr 5, 2008
    15,804
    2,389
    R!f@@ likes this.
  4. R!f@@
    Apr 2, 2009
    8,791
    771
    I guess they are ferrite.
    Can air core type have that much inductance in that size ?
  5. bertus
    Administrator
    Apr 5, 2008
    15,804
    2,389
    R!f@@ likes this.
  6. R!f@@
    Apr 2, 2009
    8,791
    771
    It's for a replacement on a PSU I get to fix from time to time.
    I was wondering what core it was.
  7. Picbuster
    Member
    Dec 2, 2013
    391
    53
    Bertus is correct it is micro Henry (uH) Milli is impossible at that size.
    many people mix-up M (Mega) or (m) milli while they want to identify micro sign which was not available at the old keyboards so the used the letter u.
  8. R!f@@
    Apr 2, 2009
    8,791
    771
    I am sure it is 2.2mH.
    I checked the Schema.
  9. MrAl
    Distinguished Member
    Jun 17, 2014
    2,556
    515
    Long ago a relative of mine worked in a place that made inductors like that, only higher quality units.
    I have a couple samples, and one is 1000uH which as you know is 1mH.
    So it is not uncommon to see small inductors with high inductance. The trick is to use very fine wire and high permeability cores. The downside is they can not handle much current at all and the DC series resistance is very high as far as inductors go.
    Will they work in a power supply? Only a very low current power supply like that for a 20ma LED, and maybe even not that great for that either. They would normally be used in tuned circuits.
    For a true power inductor you need to check not only the inductance but also the max operating current and also the DC resistance. These are all important specs for power supply inductors.
    The ones they made back then were 1 percent tolerance.
  10. bertus
    Administrator
    Apr 5, 2008
    15,804
    2,389
    Is the original coil of about the same size?
    The ones in the link can only handle currents in in mA range.
    Bertus
  11. DickCappels
    Aug 21, 2008
    2,773
    669
    I just checked a 3.3 millihenry molded inductor about that size. The inductance dropped from about 3 millihenries to 459 microhenries when I held a magnet to it. Ferrite for sure.
    wayneh likes this.
  12. R!f@@
    Apr 2, 2009
    8,791
    771
    I see.
    It's used as a filter between main smoothing caps at the primary side, between bridge and the PWM chip ( 7 pin DIL ) with built in FET
    The inductor is placed between two 4.7 to 10uf (Varies between supply types) 400V Mains filter caps.
    PS. The link shows the same inductor that blows when Chip fails
