Inductor choice for additional filter with LM2576 switch power supply
Discussion in 'The Projects Forum' started by jm-a, Jul 28, 2015.
  1. jm-a
    Thread Starter Active Member
    Oct 20, 2010
    105
    Hi all,
    I'm building a switching power supply with LM2576, and it's datasheet.
    Ouput power from trafo, before bridge and so on : 120 VA 2 x 25V
    Output power from switch power supply: 2 to 30 V and 3A
    As i plan to add and additional filter, i only want to know, if following inductors are a good choice?
    Bournes 21045 -H-R-C Toroid 22µH 7A
    http://www.newark.com/bourns/2105-h...uh-15-7a/dp/58T5313?searchRef=SearchLookAhead
    http://www.farnell.com/datasheets/666614.pdf
    Murata 3300 Series 33220C 22µH 5,1 A
    http://www.farnell.com/datasheets/1482175.pdf
    As usual, thanks a lot for your help.
    Jm
  2. Dr.killjoy
    Apr 28, 2013
    1,207
    157
    General I follow the datasheet and it say it will improve then I see no problem doing it and the parts you selected seem legit and should work..Oh almost forgot I would get the highest amp rating cause you will pull more current then the part is rated for and cause alot of issues..I would think it would saturate the coil but I might be wrong here since I am the noob.
    jm-a likes this.
  3. jm-a
    Oct 20, 2010
    105
    Thanks a lot for your help.
    jm
