Inductor and Ferrite Transformers
Discussion in 'General Electronics Chat' started by Pusle, Dec 23, 2009.
Thread Status:
Not open for further replies.
  1. Pusle
    Dec 23, 2009
    15
    What is the main transformer in a disposable camera called like the part number and everything cause mine burnt out
    And what is an inducer
    Adam
  2. VoodooMojo
    Nov 28, 2009
    503
    53
    take a very, very close look at the component on the flash circuit and Google parts of the number. You may find a replacement part that way.
    Be aware that the capacitor alongside the transformer can be holding a wallop of a charge. 400 volts in some cases BE CAREFUL!!
    There is a reason they are called "disposable"
    an inducer on a snow blower would be the impeller,
    if you are looking to induce labor, a pediatrician is the person.
    oh my, I almost forgot about the Phase Inducer on Ster Trek!
    http://memory-alpha.org/en/wiki/Phase_inducer
    an inductor, on the other hand, is a coil of wire.
    choke, solenoid, coil....
    from wiki:
    An inductor or a reactor is a passive electrical component that can store energy in a magnetic field created by the electric current passing through it. An inductor's ability to store magnetic energy is measured by its inductance, in units of henries. Typically an inductor is a conducting wire shaped as a coil, the loops helping to create a strong magnetic field inside the coil due to Faraday's Law of Induction. Inductors are one of the basic electronic components used in electronics where current and voltage change with time, due to the ability of inductors to delay and reshape alternating currents...............more...
    http://en.wikipedia.org/wiki/Inductor
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Even if you could identify a part number, your chances of replacing a damaged part in a disposable cmaera and having it work again are so close to nil as to not be worth worrying about.
  4. VoodooMojo
    Nov 28, 2009
    503
    53
  5. Pusle
    Dec 23, 2009
    15
    Ok so instead of getting that exact part here's what i want to do
    i want to create a capacitor charger with the EXACT specs as the disposable camera, the camera cap charger has an output of about 250V, the components of the charger are 1 transistor D965, 1 resistor 220ohm, 1 Diode RI500F and this transformer it is small the length of the core is 10mm and the coil bit is 6mm, it has dark blue tape around it has 3 legs one side and 2 legs other side and it says "1001 10" and the other side of the middle core says "GC"
    http://www.repairfaq.org/sam/uc350vc.gif this looks like the right one but the transformers in these schematics don’t tell me where to get them or what they are and they only use 2 legs on each side?
    Adam
  6. VoodooMojo
    Nov 28, 2009
    503
    53
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  8. whatsthatsmell
    Oct 9, 2009
    102
    Actually, that would be an Obstetrician. :)
    But, more importantly, why would one replace a flash unit in a disposable camera? Methinks this thread smacks of something more sinister. Taser perhaps? :rolleyes:
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Could be. This needs to close.
    Why all the interest in zapping someone? Then you have to worry about baseball bats used by the zapee to indicate a certain displeasure with getting zapped.
Thread Status:
