I am trying to build an Inductivity meter from websites.
Not much remains from the original schematics.
Except a comperator is used as oscillator.
Most of these schematics on the web all seem to be the same for the oscillator- a LM311, some 100K resistors, as well one 47K, and 2x 10uF caps.
It does not work at all with the 10F200 comperator.
Which in turn goes to T1CKI of a larger PIC. I am setting the TMR1H to 0xff each interrupt, so I am getting 1:256 divider right now. Resulting in audible signals. Each time I toggle one I/O for a small piezo speaker.
Here the schematic. Only using 2 components, a resistor, and one capacitor.
I have tested 22uH and 680uH so far, both result in oscillation. That is about the range I'd be interested in.
Smaller inductors don't produce oscillation for instance one toroid seem to have only a few uH. But, they change the freq. of course if they are put in series with other inductors.
What to use as formula is not clear to me.
Seems to be I have to test a series of inductors, get the numeric frequency on a display, and apply calculus maths to get the formula.
Maybe it is the same as for the original circuit only in a different form.
No idea what the relay should be good for. Except it could be used to add Lx in series to a fixed inductor, and shorten it for calibration.
Still a lot of work until I get a numeric display, but I made it oscillating.
Most of the components are unneccessary however unfortunately it needs a stable voltage or the frequency will change. Maybe I'll use a dc/dc booster with an AA battery.
Here the original schematic:
http://electronics-diy.com/lc_meter.php
I don't need a cap. meter since this is built into my DMM.
Any ideas for a good coil based oscillator?
I was thinking to try a TTL inverter but can not simulate it properly in LTSpice.
