Inductive Spike for Push-Pull car audio supply
Discussion in 'The Projects Forum' started by maxmavin, Feb 20, 2016.
  1. maxmavin
    May 11, 2013
    5
    I am facing this problem, which is causing the two push-pull MOSFET to extreme stresses.
    I am using this to power TAS5630 amp. the boost converter is converting the 12V DC voltage to 36V DC (unregulated). As this is a car amplifier so the battery voltage can be 10V to 14.5V.
    Everything is ok upto 13.5V DC input. But when the input voltage is higher than that, inductive spike is seen at the MOSFET drain and they becomes hot.
    At 13.8V or higher the kick exceeds the max Vds 40V and the FETs are starting to runaway.
    I have attached some screenshot and unsnubbed oscillation at MOSFET drain. Please help me to remove the inductive kick @15V. 0drain-gnd1 @14.5V2.png
  2. Dodgydave
    Jun 22, 2012
    5,155
    772
    Whats the circuit for the booster?
  3. maxmavin
    May 11, 2013
    5
    the schematic is inside the zip file. anyway I am again uploading...
  4. Dodgydave
    Jun 22, 2012
    5,155
    772
    what is the signal like on the gates when the voltage is altered?
    You can put an ultrafast diode like MUR460 across the drains to batt positive to clamp it.
    maxmavin likes this.
  5. Lestraveled
    May 19, 2014
    1,957
    1,218
    Are these scope photos with the power supply loaded or unloaded??
  6. maxmavin
    May 11, 2013
    5
    Thanks Dodgy for your reply. Attached is the gate waveshape. I will try to add an ultra-fast diode to see if anything is improved. Thought the snubber will be sufficient to absorb everything (ringing ,spike etc.)
  7. maxmavin
    May 11, 2013
    5
    These are unloaded waveforms.
  8. Lestraveled
    May 19, 2014
    1,957
    1,218
    Look at the waveforms with the power supply loaded.
  9. maxmavin
    May 11, 2013
    5
    Probably this is caused by the primary leakage inductance. I am thinking about rewinding the transformer. Is there any tips or guide about the winding procedure so that leakage inductance is minimum ?
