inductive sensor with LED and relay. help
Discussion in 'The Projects Forum' started by estrellainfo, May 14, 2014.
  1. estrellainfo
    Nov 26, 2008
    Good night guys,
    I have a project and I have doubts in electronics circuit.
    My idea is as follows.
    I have 2 lamps, one green and one red
    LED lamp 127volts
    I want to put an inductive sensor metal ...
    example:
    red lamp is on and passes a metal and the green lamp lights.
    and the red sensor is off .... not this more driven. lights the red lamp ....
    I plan on using 2 relay, is possible?
    someone help me?
    thanks
  2. wayneh
    Sep 9, 2010
    12,382
    3,239
    Do you want to build a traditional metal detector? There are many, many available examples of these.
    You may want to use standard LED indicators, which are easily powered by a battery, instead of the one you have that requires mains voltage.
