Thanks all, for your responses. Sometimes I get carried away by the theoretical when working on electrical/electronics solutions, and forget the KISS principle
I went with the silicone wire because it's easy to find on Amazon where I'm ordering a bunch of the other parts from, and the wire is rated at 200˚C; I don't think the pipes exceed 150˚C so I've got a comfortable margin just in case the pipes can get a little hotter than what I measured, or if the wire is cheap imported crap and overrated.
It's 16AWG, which should be more than enough for the 12V/1A that I'm supplying; the LED strips I'm using should total around 800mA. I could've gotten away with 18AWG easily, but the gap is large enough to accommodate 16 and the cost was about the same so I felt there was no reason to go with 18.
