induction motor
Discussion in 'General Electronics Chat' started by eagle55, Mar 22, 2010.
  1. eagle55
    Mar 9, 2010
    6
    inserting a capacitor (parallel) into a induction motor power supply,would current draw reduce?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    An induction motor is inductive in nature.
    If a load is inductive or capacitive, it will have a low power factor, and appear to use more power than it actually is.
    If a load is purely resistive, it will have a power factor of 1.
    Adding capacitance to an inductive load can help to correct the power factor.
    Adding inductance to a capacitive load can help to correct the power factor.
    Google "power factor" for more information.
  3. eagle55
    Mar 9, 2010
    6
    thanx SgtWookie :)
  4. Duane P Wetick
    Apr 23, 2009
    408
    19
    Inserting a capacitor across a motor winding will definitely improve the power factor; ie, reducing current demand from the source while motor current is un-changed. There is another advantage in doing this and that is an increase in motor torque.
    Cheers, DPW [ Everything has limitations...and I hate limitations.]
