Induction motor speed control
Discussion in 'The Projects Forum' started by brunounreal, Feb 28, 2012.
  1. brunounreal
    Apr 23, 2010
    26
    i'm researching for a project that i'm begining about a speed control for a induction motor.
    I'm searching for a IC that can do the control of a full Bridge Inverter using pwm with unipolar voltage switching to drive a monophasic induction motor.
    does anyone who have some knowledge in this area could give me a little help? i would be very greatful.
  2. crutschow
    Mar 14, 2008
    13,475
    3,361
    A good place to start is a PWM controller chip such as one of these from Texas Instruments. They are designed for switching power supplies but can be readily adapted to control a PWM bridge to power your motor.
  3. brunounreal
    Apr 23, 2010
    26
    those dont work as i want because the pwm is given by comparing a triangular wave with a dc value and i need to comparate a triangular with a sinus wave to obtain a modulated wave.
  4. shortbus
    Sep 30, 2009
    4,088
    1,669
    While you could probably do it buy physically modifying the motor, a single phase motor does not lend itself to variable speed. This is assuming that a single phase motor is what your calling "a monophasic induction motor. "
    The reason is that single phase does not produce a "rotating magnetic pulse" on its own. It uses a separate winding controlled usually by a 'centrifugal switch' and a capacitor for starting.
  5. crutschow
    Mar 14, 2008
    13,475
    3,361
    They can work if you sum the sine wave into the error amp input along with the filtered output voltage. The chip will then compare the output voltage with the sine wave input and adjust the output to match in the input sine wave.
    Or you can run it open loop by just replacing the dc input with the sine wave input in the error amp.
  6. R!f@@
    Apr 2, 2009
    8,785
    771
    Just delete it.
  7. crutschow
    Mar 14, 2008
    13,475
    3,361
    And how do you do that? :confused:
  8. R!f@@
    Apr 2, 2009
    8,785
    771
    On ur post click edit and there u will see delete button.
    Then u have to high light the delete message option and enter.
    shortbus likes this.
  9. crutschow
    Mar 14, 2008
    13,475
    3,361
    Got it. Thanks. Guess it's a thread that you can't delete.
  10. shortbus
    Sep 30, 2009
    4,088
    1,669
    Thanks R!f@@ ! Didn't know you could do that.
  11. R!f@@
    Apr 2, 2009
    8,785
    771
    Welcome guys.
    There is a way to delete a thread. Wanna know ?
  12. shortbus
    Sep 30, 2009
    4,088
    1,669
    Ok, I'll bite.
  13. Georacer
    Nov 25, 2009
    5,151
    1,266
    Sure. Go to "Moderating Tools"->"Thread Actions"...
    ...oh wait...
    ;P
  14. R!f@@
    Apr 2, 2009
    8,785
    771
    Start Politics or Preaching :D
  15. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    yuck!! the two subjects i hate.
    Now get this thread back on topic! There are single plase motors that dont use a start/run cap, these can easily be VFD'd, i did it with a shaded pole motor.
  16. shortbus
    Sep 30, 2009
    4,088
    1,669
    Good one R!@ff
