Induction motor in state space
Discussion in 'Math' started by kokkie_d, Nov 24, 2010.
  1. kokkie_d
    Thread Starter Active Member
    Jan 12, 2009
    From literature the induction motor has been well described in state space, see attachment- Induction Motor-01.jpg:
    This equation describes the induction motor with a rotating rotor.
    To describe a rotating stator as a consequence of the 3 phase supplied power, the following equation can be used, see attachment - induction motor - rotorary frame -02.jpg:
    Now, my question is the following:
    I have a little difficulty understanding the second equation, the one showing the inclusion of the rotorary stator frame.
    Because when I simulate a power supply (through the use of 3 combining 3 sine waves set 120 degrees apart)
    <br />
3 phase = A*(sin(\omega t+\theta) + sin(\omega t+\theta+2\pi/3) + sin(\omega t+\theta - 2\pi/3))<br />
    then I can control the amplitude by adjusting A and the speed by adjusting f within \omega and any start angle by \theta.
    This should give me control of the motor by adjusting its power supply and I would not need the rotorary frame reference?
    On the other hand if I use the rotorary frame reference I only need to control the amplitude of the signal and the speed within the stator, right?
    Are my last statements true?
