Induction motor connections
Discussion in 'General Electronics Chat' started by rvh002@gmail.com, May 15, 2009.
  1. rvh002@gmail.com
    Thread Starter Active Member
    May 15, 2009
    118
    Hi, I need some info on cennecting a 3 phase induction motor to a single phase supply. The star and delta methods and the way to calculate the capacitor size. Thanks
  2. rvh002@gmail.com
    May 15, 2009
    118
    You can indeed run a 3phase motor on a aingle phase supply. In the section on Ac motors of this forum it gives an example but not to much detail
  3. mik3
    Feb 4, 2008
    4,846
    63
    You can run a 3 phase motor with a single phase supply if you connect two of its terminals between neutral and live and put a capacitor between the third motor terminal and live wire.
    However, this reduces the output power of the motor and draws more current from the grid.
    Note that it is illegal to wire large three phase motors like that.
  4. rvh002@gmail.com
    May 15, 2009
    118
    At the top of the page you will find a bar with references to some manuals.
    Click on volume II>Chapter 13> AC motors> Tesla polyphase inductive motors.
    Read the whole section, it explains it quite nicely
    Regards
