I got this kit years ago and could never figure it out:
2 stands with springs and magnets (the magnets hang from the springs, which hang from the stands).
2 large hollow coils.
2 alligator clips.
No instructions whatsoever.
I assume the magnets hang from the springs, which hang from the stands. The magnets are to be at neutral within each coil. The alligator clips are to complete a circuit between the coils.
I assume one magnet should be made to bounce up and down from the spring, which should induce a slowly alternating current within the corresponding coil, which will induce a slowly alternating magnetic field within the second coil, which should cause the second magnet to bounce up and down.
This never happened
I assume the induced current or magnetic field is too low?
Or is my physics way off?
2 alligator clips.
This never happened
