induction heater
Discussion in 'The Projects Forum' started by jaangalab, Jan 18, 2011.
  1. jaangalab
    Mar 28, 2010
    12
    hi frnds i want to make a induction heater 5kw can any body share me idea
    thanks with regards
    er.sandeep sharma
  2. wayneh
    Sep 9, 2010
    12,374
    3,225
    You'll need to supply more details to get much help here, including what your own personal skills and capabilities are. 5kW is a lot of juice and therefore carries risk and dangers.
    What are you really hoping to do?
  3. jaangalab
    Mar 28, 2010
    12
    i am graduate from electronics i am familiar from hf induction welder raging from 30kw to 600 kw used in pipe mfg triode type what now need small heater to heat small parts of soft iron tube is so costly so i want to make it solid state
  4. jaangalab
    Mar 28, 2010
    12
    dear frnds
    if no body wants to help me ok frnds i dot feel
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    English not native language, I suspect?
    Question comes off a bit gruff, but we need a bit more information on this to really be of any help.
    What is the size of the item to be heated? Do you have a schematic for a driver you want to convert?
    Have you worked with lethal voltages at the component level before?
