Induction cookers
Discussion in 'General Electronics Chat' started by tady, Mar 15, 2016.
  1. tady
    Nov 7, 2008
    18
    Hello everyone!
    Does anyone have experience with induction cookers? I have a gorenje induction hob and it blew the igbts, zeners and the rectifier. I changed ecerything including the 10 ohm resistors and it started working again. Nice switching waveforms.
    The cooker was put to the test and we cooked about 10 meals. Then it blew again.
    Does anyone know why this happens?
    The driving stage uses gate transformers.
    Any info is welcome.
    Thank you!
  2. wayneh
    Sep 9, 2010
    12,368
    3,224
    Do you have a schematic?
  3. tady
    Nov 7, 2008
    18
    No i dont :/ two igbts connected in series between the supply (320v) and the center si connected to the coil. The other end of the coil is connected to the center of the two capacitors enf the free ends are connected to the power suppy... Something like this.... http://i.stack.imgur.com/c57lE.png but without the C1 on the power supply. There is a optocoupler on the power supply end. I think it is used to detect 0v (zero voltage switching)
  4. ISB123
    May 21, 2014
    1,240
    531
    Could be a problem with your house voltage.
  5. tady
    Nov 7, 2008
    18
    I boubt it. I forgot to mention that the cooker was blown when my friend gave it to me... I fixed it.. It was working for about 14 days and it blew again. I will try it again with 1200v igbts ;) if they blow up again it has to ba a current or shot trough problem..
  6. ISB123
    May 21, 2014
    1,240
    531
    If it blows the whole circuit the problem is most likely in the power supply.
