Inductance of different metals
Discussion in 'General Electronics Chat' started by Shagas, Dec 15, 2013.
  1. Shagas
    Thread Starter Active Member
    May 13, 2013
    802
    74
    Hello
    So while having dinner I decided to refresh my knowledge on LC tuned circuits
    by watching a video from this Guy : and one thing led to another which ended up with me coming across this inductance calculator.
    I noticed that an increase of wire length increases the inductance more than linearly but more interestingly that picking different metals had almost no effect on the value of inductance except ...Nickel. When I pick nickel the inductance value shoots up dramatically .
    Are those numbers legit? Is nickel really that inductive?
    Does nickel have any specific use in electronics or PCBs?
  2. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Nickel is ferromagnetic so has a much higher permeability than, say, copper. The inductance of a coil depends on the permeability of material used in its construction, as well as on the coil dimensions and wire length.
  3. tshuck
    Oct 18, 2012
    3,531
    675
    Iron, Cobalt , an Nickel are the only magnetic metals and will each exhibit this jump in the numbers, per Alec_t's reasoning...
  4. Shagas
    May 13, 2013
    802
    74
    Hmm yes makes sense .
    What I didn't expect though is that the inductance increases more than linearly with increasing length.
    At 1Mhz , 1cm of 1mm copper wire has inductance of about 6nH and at 10cm about 105nH which is more than 10 times the amount.
  5. GopherT
    Nov 23, 2012
    6,339
    4,083
    For a high Q, you want DC resistance to be as low as possible. Copper is generally preferred for high Q inductors. Ferrites, iron powder, silicon-steel (ferrosilicon), permalloy are generally the core materials used to increase inductance.
    Shagas likes this.
  6. Alec_t
    Sep 17, 2013
    5,980
    1,138
    That depends how the wire is configured. If it's wound uni-directionally into a cylindrical coil the coil inductance varies as the square of the number of turns; which tallies with the figures you quoted.
    Shagas likes this.
  7. Shagas
    May 13, 2013
    802
    74
    Interesting to know , but this calculator shows values for a straight wire.
  8. BillB3857
    Feb 28, 2009
    2,402
    348
    Back in the dark ages, I had a phenolic rod about 1/4" diameter, 6" long, with a ferrite slug on one end and a brass slug on the other. It was used to determine whether the tuning slug of a tank circuit needed to be screwed further into or further out of the coil. If the ferrite slug was placed close to the tank, and the signal response improved, the slug needed to be screwed into the coil. Likewise, if the brass slug placed near the tank improved response, the slug needed to be moved outward from the tank.
  9. Tesla23
    May 10, 2009
    323
    67
    These formulas are based on the work of Rosa
    "The Self and Mutual Inductances of Linear Conductors", E B Rosa, Bulletin of the Bureau of Standards, Vol:4, No:2, 1908
    where he considers the self-linkage of flux for a fixed length of wire. There is a certain arbitrariness in the calculation in that he ignores flux past the perpendicular planes at each end of the wire, but the results have proved useful. The reason that it increases faster than linear in 'l' is similar to the coil analogy. Consider connecting two half sections to double the length. Each section has a self inductance, but some flux from each half also links the other, resulting in the self inductance increasing by more than a factor of 2.
    The original calculations are understandable, see here:
    http://www.g3ynh.info/zdocs/refs/NBS/Rosa1908.pdf
    I'm surprised that using the calculator you linked that the inductance for copper and nickel don't converge more at high frequencies (e.g. 10GHz) as then there would be minimal fields in the conductor, but I haven't investigated.
