This will be my first post, so if I inadvertently violate a house rule, let me know.
My question is this. I need some very low-value resistors (well under 1 Ω), and I am going to make them by using a known length of nichrome wire. That would give me a resistor that is also an inductor. However, it occurred to me that if I wound half the wire clockwise, and then reversed and went counterclockwise, I should have created two possibly cancelling magnetic fields. After all, no magnetic field, no inductance, eh?
So I tried this, using a magnetic compass as a detector, and the compass needle swung 7 degrees with the coil would only clockwise, but only about 1 degree for the coil with the reverse in the middle (all other conditions being equal).
So, was I fooled, or does this idea make sense?
Thanks in advance for any responses.
jrdoner
jrdoner
