inductance meter
Discussion in 'General Electronics Chat' started by samjesse, Dec 12, 2009.
  1. samjesse
    Thread Starter Active Member
    Sep 14, 2008
    202
    Hi
    I was thinking to buy an inductance meter. ebay has many MIC "made in china" ones, are they any good? should I build my own? even if I do, I will be sold MIC parts, so whats the go?
    thx
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. talking
    Dec 10, 2009
    12
    The biggest problem with building your own inductance meter, is calibration.
    At least the bought units are calibrated and when I built my own, I needed a built-up unit to check and calibrate the one I designed.
    You have absolutely no idea if the one you build, is accurate.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You can calibrate the PIC versions using 1% capacitors. The LC measurements will be slightly less accurate than the calibration capacitor used. However, unless you spend a boatload of money for a commercial version, it probably won't be a whole lot more accurate.
  5. Duane P Wetick
    Apr 23, 2009
    408
    19
    You may be able to find a General Radio Q meter (vacuum tube) in working condition by canvassing the second hand electrical parts warehouses; Fair Radio in Lima, Ohio and All Electronics in Oxnard, CA. I talked to the man who used to build these units and he supplied me with an instruction manual for a second-hand unit that we acquired. They also made (canned) standard inductors for calibration purposes.
    Do a thorough search on the internet before you try building anything as a unit may be found almost anywhere.
    Cheers, DPW [ Spent years making heaters out of op-amps.]
  6. KL7AJ
    Nov 4, 2008
    2,047
    295
    Dear samnjesse:
    In the dusty musty dungeon of the electronics storeroom of my A.C. electronics class, I discovered a lovely little box, a Leader LCR 740 resistance/ reactance bridge. It's a surprisingly accurate little feller, and does it all: resistance, capacitance, inductance, Q, D, and ESR (equivalent series resistance).
    I've seen these crop up on E-bay for as little as $100.
    As suggested above, building a bridge is a very educational and worthy project, but the calibration can be rather tedious. For the price of the LCR 740, you'd be hard pressed to find a better instrument.
    Also, keep your eyes peeled for old Heathkit or Boonton Q meters and component bridges. They have an additional "cool" factor beyond the Leader boxes. :)
    Eric
