inductance from graph
blpanther
Joined Nov 23, 2015
5
Hi, Need help with some questions:
I need to determine the inductance from the gradient of graph (graph is showing frequency changing from 500-2500Hz vs inductor voltage) circuit current is kept same by increasing signal generator voltage... The gradient of the graph is vertical length divided by horizontal length but if I use that it doesn't even come close to the value of inductance (which is 100mH).
Alec_t
Joined Sep 17, 2013
14,313
We're not psychic ;).
If frequency is along one graph axis, what is along the other axis?
Apart from an inductor, what else is in your circuit? A schematic of your circuit would help.
blpanther
Joined Nov 23, 2015
5
on the other axis we have inductor voltage. in the circuit there is only a resistor and this inductor (in series) plus a signal generator.
30,802
Units, units, units!
\(Reactance = \omega L\)
Reactance in ohm.
\(\omega = 2\pi f\) in radian/s
\(L\) in Henry.
\(L = \frac{Reactance}{2\pi f} \)
The denominator \(f\) is in Hz multiplied by \(2\pi\).
The numerator is in ohm.
blpanther
Joined Nov 23, 2015
5
so on the graph I have following points
(0,0) and for example (2500,950) - frequency and voltage respectively.
If I divide 950/2500 I get 0.38 as graph gradient. How does that relate to inductance (which is 100uH) ?
