Inductance dimensionning
bertus
Joined Apr 5, 2008
22,278
Did you see fig 31 on page 14 of the datasheet?
It has some graphs on the inductor ranges.
Also look at page 15 for the formulas to make the calculations.
Bertus
BobTPH
Joined Jun 5, 2013
8,998
And, yes, the inductor is the key component that makes a buck regulator work. Without it you would simply be PWMing the input voltage to the output.
Bob
34,462
That is a switching regulator to give high efficiency conversion of a high voltage to a lower voltage.
The output of the IC is a PWM signal switched between 0V and the input voltage, with an average value equal to the desired output voltage.
This pulsed voltage could be smoothed with an RC filter but that would dissipate power in the resistor and give no better efficiency than a linear regulator.
Thus the "why" we need the inductor, is to losslessly absorb the pulse energy (stored energy = ½ LI²) and store some of it between pulses while transferring it to the output.
This, in conjunction with the output capacitor, give a steady DC output voltage with only a small ripple voltage.
Since, with proper design, this switching conversion process will have low losses, it is much more efficient (for significant differences the input and output voltages) than simply dumping the excess voltage across a variable resistance as heat, which a linear regulator does.
