1)A rectangular frame ABCD made of a uniform metal wire has a straight connection between E & F made of the same wire as shown in figure. AEFD is a square of side I meter and EB=FC=0.5 meter. The entire circuit is placed in a steadily increasing uniform magnetic field directed into the plane of the paper and normal to it. The rate of change of magnetic field is 1 Tesla/sec. The resistance per unit length of the wire is 1 ohm/meter. Find the magnitude and direction of the currents in the segments AE,BE & EF.
My question is will an e.m.f be induced in a stationary coil just by placing it in a steadily increasing uniform magnetic field? They have solved it using this concept. Is it possible?
