A conducting rod of length l = 35 cm is pulled along two frictionless, parallel conducting rails at a constant speed of 8.00 m/s, as shown. A constant, uniform magnetic field B = 2.50 T is directed vertically into the page. Two resistors, R1 = 2.00 Ω and R2 = 5.00 Ω, are connected between the rails and offer the only significant resistance in the loops.
The rod is allowed to come to rest somewhere between the two resistors, after which the magnetic field begins to steadily increase in strength. Explain what happens to the rod.
I understand by Lenz's Law that since there is an increase in magnetic field into the page, the induced field will point out of the page, but then how would you work out the direction of the current, since you cant use the right hand rule, since the rod is at rest?
