indoor antenna -> to -> Transmitter
Discussion in 'Wireless & RF Design' started by Bob T., Oct 23, 2012.
  1. Bob T.
    Oct 22, 2012
    35
    Hello and piece.....
    I bought an indoor antenna like this:
    I wanted to change this antenna from receiver into a transmitter for my robot, and i am using Holtek ICs to send and receive instructions.
    So how can i change this kind of antenna into transmitter?
    Or its better to use external antenna like this one:
    :D
    Thank you all..................
  2. Bob T.
    Oct 22, 2012
    35
    The problem is i want to amplify the radio waves so i can control my Robot from a large distances.
    Tnx.....Bob
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    The size of an antenna is determined by its radio frequency.
    But you forgot to tell us your robot's radio frequency.
  4. Bob T.
    Oct 22, 2012
    35
    its about 435 Hz
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    435Hz is a fairly low audio frequency, not a radio frequency.
    Is it actrually 435MHz?
    If you make a directional antenna then its range is better than a single vertical whip antenna. Look in Google for Yagi antenna.
  6. wmodavis
    Oct 23, 2010
    737
    150
    Hook it up to a transmitter instead of a receiver. Then impedance match it so that the transmitter power actually gets to the antenna.
    Bob T. likes this.
  7. Bob T.
    Oct 22, 2012
    35
    i will try this, but do i need an amplifier?
  8. PRFGADGET
    Aug 8, 2011
    51
    7
    A "Gain" antenna on the transmitter and the receiver will make a good difference.
    As to an amplifier , that all depends on how much range you are trying to get out of the system (you haven't told us that).
    The "rabbit-ears" type antenna can be made to work but probably not as well as a antenna (s) actually designed for the frequency in question.
    Directional antennas will have more gain but depending on what you are trying to accomplish may present other problems (as in keeping the antenna pointed in the proper direction).
    Bob T. likes this.
