Simply put, if the resistance of a capacitor increases as it charges, can I send periodic DC pulses into it causing the voltage across it to eventually rise to its maximum rated power, thus finally fully charging it?
For example, in a very simple circuit of a power source, resistor and capacitor, as the relative resistances of the resistor and capacitor change over time, the capacitor should incrementally increase in voltage even though the power source is sending the same peak voltage out with each pulse? (Assume negligible cap discharge and the ability of the power source to match the cap voltage once the respective resistance change sufficiently)>
