Incremental Encoder Library for Beaglebone
Discussion in 'Embedded Systems and Microcontrollers' started by ramses, Apr 26, 2015.
  1. ramses
    Nov 5, 2013
    17
    I use incremental rotary encoder to measure angle with Beaglebone. But I dont have any experience on decoding encoder.
    http://www.farnell.com/datasheets/1599245.pdf
    Can you share any rotary encoder library for Beaglebone? I need a starting point.
  2. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    These are simple incremental quadrature encoders, two square wave pulses separated by 90°.
    They show either open collector or line driver.
    Often a system will use either the two rising edges or all four edges to increase the resolution by x2 or x4.
    The technology used for anything over ~50pulses/rev is done using the Moiré technique.
    Max.
