Increasing ultrasonic distance
Discussion in 'The Projects Forum' started by lanmam, Jan 23, 2011.
  1. lanmam
    Jan 23, 2011
    May i know can i upgrade it to measure up to 100 meters?
    If so which part have to change ? the circuit one or program?
    Thanks.
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    6m Sensor
    Beyond transducers, increasing range needs high sensitivity op amps and a good bit of noise rejection. The unit above has a good deal of it set up, but it is the cost of 4 basic ultrasonic rangefinders.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    For anything beyond 20 feet, you'll more than likely end up using a laser ranging solution.
    Expense goes up by a factor of 10 or so.
