increasing the range of clamp on ammeter
lokeycmos
Joined Apr 3, 2009
431
hello, my clamp on ammeter is rated for 400 amps max. I am looking into increasing this to 4000 amps. I know that it is possible, but looking for some more input and suggestions. I could possibly wind my own 10:1 transformer but not exactly sure how to go about it. please advise! ty
#12
Joined Nov 30, 2010
18,224
There is a shunt resistor inside the meter to calibrate the range. Take it out, divide by 10, and put a different resistor in.
#12
Joined Nov 30, 2010
18,224
Those transducers are built for about a milliamp, but overheating is a thing to consider. Be sure to run the numbers,lokey.
joeyd999
Joined Jun 6, 2011
5,287
Just had an idea:
Opening the clamp should attenuate the reading. If you have a calibrated current source, perhaps you could determine the gap size that gives you 90% attenuation? Not sure if this would work with all geometries and positioning of the wire, but you lose nothing by trying...
