Hi all,
I've been thinking recently about trying to increase the range of my RFID reader system, I'm stuck with the lf type of RFID 127~134 kHz used for id in livestock. I've a reliably working system using the Atmel U2270b front end chip.
Range of these tags is quite short and as far as I can see there are two ways to increase range, a bigger reader coil or pushing more current through a given size coil?
I've got pretty much as big a coil as practical for my hand held reader so am now thinking of ways to get more current through. I think I'm going to have to use a MOSFET H-bridge and drive it with the PWM module on my pic as I think I've reached the limit of supply on the Atmel.
This is where I could do with some help, the reader at the moment uses a 9v battery and also has to detect a HDX transponder (which means the field is turned off to wait for the HDX to respond).
Is it practical to use a step up boost converter to charge a capacitor to a higher voltage, say 30v while the field is off then use the 30v to supply the H-Bridge and hence drive the coil at a higher current? All be it briefly!
I've been doing a bit of reading up and read that a capacitor used for storage is about 50% efficent? Is this correct? Anyone have any idea what sort of losses I might experience with the boost converter etc? I've a funny feeling they might be quite high.
Thanks Geoff
Thanks Geoff
