Increasing/Decreasing the frequency in an AC circuit
Discussion in 'Electronics Resources' started by LaserPhile, Apr 24, 2015.
  1. LaserPhile
    Apr 24, 2015
    7
    I have a pretty simple question. I need to know how to go about modifying the frequency of an AC circuit. What components would I generally use to go about accomplishing this. I am pretty new to electronics, so bear with me. Any input I could get on this would be extremely helpful. Thanks
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    What do you mean by the phrase "frequency of an AC circuit"?
  3. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Welcome to AAC!
    Does your circuit generate this mystery frequency or respond to an input signal having the frequency?
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
  5. ScottWang
    Aug 23, 2012
    4,925
    777
    If you don't have the schematic then you should draw a block diagram to show what you want, and provide some more infos as V/I/F, etc ...
  6. LaserPhile
    Apr 24, 2015
    7
    Maybe my question doesn't make much sense. What I mean is I would like to take the 60 Hz coming out of the wall and change it to an arbitrary frequency. For example, I would like to know what circuit elements I could use to change it from 60 Hz to 30kHz or really any arbitrary frequency.
  7. Ramussons
    May 3, 2013
    562
    92
    No, you cannot Change it to an arbitrary frequency. You can distort the waveform from a Sine to a Square or Triangular and pick up the Harmonics - 120 Hz, 180 Hz, .... with the content of the Harmonics decreasing rapidly and making this too impractical beyond, say, 10th harmonic.
    You can generate an arbitrary frequency using an oscillator, and one way of powering that oscillator can be from the " ... 60 Hz coming out of the wall..."
  8. LaserPhile
    Apr 24, 2015
    7
    Ah! I think I figured it out. What I'm looking for would be a function/waveform generator. I would just need the "60 Hz coming out of the wall" to power the circuit, but the frequency generated by the function generator would not depend on that, nor would the 60 Hz be "changed" per se. Thank you.
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Which was described in post#4
    LaserPhile likes this.
  10. LaserPhile
    Apr 24, 2015
    7
    Ha! I must have just missed it while looking over the replies.
