So I just realized the 75 ohm resistor above (R6)... is this going to mess with the 4.7 ohm (5w) resistor thats used in front of the darlington transistor?A 3.3, 4.7 or 5 ohm would be better (in that order as fat as I'm concerned). The darlington transistor will drop a minimum of 1 volt, so your 15 V supply is down to 14. 8 ohms from your fixed resistor and an 8 ohm load mean you only get (14V/16 ohms) of current through the load.
