Hi Folks
I'm quite a novice when it comes to circuits.. So hopefully someone could please help with the following problem I'm facing..
I've got a vehicle tracking system that logs when a vehicle door is unlocked. It is negative triggered and as such when the door is locked a voltage of 0.14-0.16V passes over the central locking unlock wire. When I unlock it drops to 0.
The issue is my tracking devices only pick up the door as locked if the voltage across the central locking wire is >1V and as such interperets the 0.14-0.16V as unlocked, even though it is not.
I have tapped in to the door wire and I'm running off a seperate feed, I also have a 12V DC supply if required. The input for my tracker can take up to 45V, 500mA max. Could someone kindly recommend a work around to get me from 0.14-0.16V input to >1V output while still allowing for the voltage to drop back to 0 when unlocked?
Thanks in advance
Steve
Thanks in advance
Steve
