I mod Xbox's and now XBOX 360's. The new system uses SMD LED's, these babies have a completely different power consumption then what I am used to dealing with which are *3mm 5000mcd bulb type led's*. Not to mention the different power supply to the wireless controllers.
On the ring of light it's easy enough to replace the SMD LED's with the color of your choice. However, the replacement LED's are usually much dimmer then they should be given the voltage they are supplied with. What I want to do is increase the power to these LED's thus making them brighter.
What I've come up with so far is jumping power from the batteries, or battery pack to each of the four LED's. This will keep them on at all times, and hopefully make them much brighter. The problem is the rechargeable battery pack provides only 2.4v of power where the batteries *two AA batteries* provide 3v max.
What I think I need is a capacitor to increase the voltage from the battery pack, or batteries to the LED's. What I can't figure out threw reading MANY different forums is what kind, or even if this will truly work.
I know the power I want to reach the four LED's is equivalent to a 9v battery with a 100Ohm resistor. The LED's are MUCH brighter when powered like this. I'm not sure what that equates too, and the combination of these issues has brought me here. ANY help on this issue would be greatly appreciated. Thank you for your time.
Please let me know if you need more info, and as I'm quite new to this field, please use layman's terms. Ready and willing to learn, so, figured I would try here.
